96 accord ex p/s a/c removal
#21
got my p/s out today except for those damn hoses that go underneath the intake. what do they go to?
and also can i just drain the ac system myself and if so how do i go about doing this
#22
Just measure it in inches, and count the number of "ribs" on the belt.
As for draining your AC, it is technically illegal to do yourself, as its illegal to release the chemicals into the atmosphere. But just undo any of the valves or pipes and it will release it.
#23
Naughty, naughty. You can get frostbite from the R-134a refrigerant. It's safer to just unscrew one of the caps and push the Schrader valve in with a small screwdriver wearing gloves. Just like giving someone you don't like a flat tire...
#24
after relieving the pressure where would be the best place to drain the fluid? i may just leave the components in there for awile and research this a little more. it looks like the new belt will have plenty of clearance without taking the ac out.
#26
holy **** its gonna be a straight up gas. damn maybe i should just take it to a shop. im sure they won't charge too much to take out the stuff
#28
just one more question. how tight should i have the alternator belt. it seems to be tighter without having the adjuster bolt only halfway to where it was with the ac on. i can push on the middle of the belt and it barely moves at all the way its on right now. is this good?
fperezal
08-17-2006 12:21 AM
