96 Accord F22B1 OBD1 to OBD2 Swap
Hello,
Been looking for details on what is involved to make a F22b1 convert from OBD1 to OBD2. Lost engine in 96 OBD2 and found a OBD1 engine and want to make it drop in car as it was. It appears I need to change the oil pump housing and not sure what else. Any help will be greatly appreciated.
Have to use 96 dizzy for the other didn't come with it.
Then yes, you will have to swap the oil ump housing and sensor from the 96 to the 95. Then since you are "there" you might as well do the timing belt job - you will now have a "base line" as to when it was last done.
The crank pulley for the belt is different. Basically the whole housing and anything "forward" of it will have to be moved.
At some point you might want to think about the cost of a new/used dist for the 95 and just run some new wires.
Got it all apart wasn't that bad to take apart. Wanted it all resealed anyway. Thanks for the info hope to have together in the next couple days.
Bacondoggy
10-05-2009 11:27 PM
