'96 Accord LX - Low compression on all 4 cyclinders
#22
I can see why temperature could matter, but throttle? I would think that even at no throttle, enough air can get in for the engine can run at idle with no throttle and the starter runs the engine at a far slower speed than that. So it would seem to me that the throttle wouldn't matter.
#23
When doing a compression test, you disable the fuel pump and the ignition system. You push down on the gas pedal when trying to start the car, so the engine can pull in the maximum amount of air to get an accurate reading.
I did a compression test without a wide open throttle and got readings similar to yours.
#24
Since you're having idle problems too, you might want to do a web search on the phrase "Honda IACV explained" for more info.
#25
To report back, I had the compression tested, it came back 180, 175, 175, 185 much better than the 120,120,120,120 that the Honda dealership claimed.
Afterwards, The mechanic started knocking, from what I could tell just random, things with a screwdriver handle, till he could reproduce the idle dropping. He ended up re-seating the end of a wire back into a plug saying that that would probably fix the idle problem.
Now my issue is what is the proper course of action in complaining to Honda dealership concerning their compression test.
Since it was asked - The brand of spark plugs used was Autolite.
#26
Never give them another dime of your money, tell any Honda-owning friends & family that dealership's service dept. is a ripoff, and write reviews of exactly what happened online: google maps, etc. Nothing libelous, just the facts.
#27
So what I did do is contact the manager of the service dept and he listened which is a good sign. He also credited back all the money I spent, including the external compression test which is also a good sign. I will assume that he'll appropriately deal with the issue internally.
I doubt, I'll be spending money at the first shop or the dealership other than oil changes; I bought an oil change service contract when I purchased the car that gives highly discounted oil changes (the cost of an oil filter about $8.00). At this point I do not see any reason to throw away that investment. Between the three shops, the only shop I trust is the last one so it will get my business for other issues.
Thank you all very much for all the help. If I can help you folks, please let me know.
Please enjoy the holidays.
#29
To my knowledge the coolant level is fine and there is no trapped air. Neither shop has ever mentioned the coolant as possibly being an issue with the idle so I have no idea if the coolant was checked. So there has been no issue with the coolant.
LINK EDITED BY poorman212
#30
Honda dealership: O'Brian Auto Group of Salem (Oregon) that failed a compression test.
