96 accord no windows, a/c, fans
Old 10-31-2013, 05:33 PM
Originally Posted by silveraccordvtec
Got voltage readings as follows: ... #21-0 (off) 0 (ignition on II) 0 - engine running...
Under-hood Fuse No. 21 (20A) – should be hot at all times, no power going to radiator fan relay. Problem at under-hood fuse box if no power there at the 20A fuse. Check the electrical harness connector and wiring under the fuse box...
Here are some checks you can make:
  1. Normally this test is to check the operation of both the radiator fan and the A/C condenser fan; however, since you’re not receiving power at the No. 21 fuse in the under-hood fuse box for the radiator fan relay, the radiator fan will not run in this test. Disconnect the 2P connector at the Engine Coolant Temperature Switch A (located on the thermostat housing, lower radiator hose); with a wire or small paper clip, jump the terminals on the harness connector side. Turn the ignition to ON or START, does the condenser fan run strongly? If the condenser fan runs strongly, the condenser fan motor, A/C condenser fan relay, and wiring is good at that portion of the circuit.
OK, so I jumped ECT A and both fans immediately came on full speed.
A1: Unless, you’re testing a different fuse than what is shown in the circuit diagram as No. 21 (for the radiator fan relay) or some wires have been re-routed; if the radiator fan runs via power coming through the radiator fan relay, power has to come through the No. 21 fuse.
I'm defenitely on under hood fuse #21 according to alldata and my fuseblock cover ... My engine does not overheat, but the cooling fan never comes on now, nor will the condenser fan come on when the a/c button is pushed. They all stopped working at the same time a/c went out. Thanks for your help.
Something doesn't add up. The radiator fan should not have came on if there was no power at the No. 21 fuse. An issue at the No. 21 fuse would cause the radiator fan not to be able to run.
  #32
Old 11-04-2013, 08:32 AM
silveraccordvtec's Avatar
Radiator fan is new, condensor fan also works. Both have been jumped and do work. A/C refrigerant reading is 35-45 lbs. Is it possible to have that pressure reading and it not be refrigerant? If not actually refrigerant pressure, then might the compressor somehow not operate? Thanks for your help.
  #33
Old 11-04-2013, 09:42 AM
Pressure switch limits are 28 psi low pressure cutoff and 455 psi HP cut-off. If air temp was near pressure measured, there could be adequate refrigerant. If air temp was 20-30 degrees above pressure measured, then refrigerant is quite low and compressor might kick on and quickly cut off.
Performance suggests low refrigerant and a significant leak somewhere.
Suggest jumping thermoswitch A and turning keyswitch to ON. Check both cooling fan connectors for power. If condensor fan has no power, then check condensor fan relay by swapping w/ radiator fan relay. If still no power, wiring fault, or fuse problem.
horgad
12-10-2006 07:57 PM
91boz
11-29-2006 03:35 PM
th22ek9
09-13-2006 11:11 PM
th22ek9
09-08-2006 09:07 PM
Fredi95EX
06-16-2005 11:07 AM
Quick Reply: 96 accord no windows, a/c, fans
