97 Accord A/c not working
ok i have a 97 accord se, the a/c is not working, when i turn it on the fan doesnt come on at all, but i think the compressor belt turns. the heat works though. I have checked the fuses and relays and i think they are ok. im frustrated because its HOT and I need a/c cause i have a little one. if anyone could help me please do!!! how do i know its the compressor? how do i know its the A/c switch?
NOTE: my front passenger wheel well cover came off and the wire harness rubbed against the tire, would that have to do anything with it? but I check and its just the front headlights and radiator fan that are on the front passenger side, would that cause my a/c to not work?
Does the compressor engage? When you turn on the A/C you'll hear a click if the hood is up and see the center of the compressor start to turn. If the A/C is off, the center of the compressor will not turn. Thats a simple place to start.
Either need to repair or replace that harnes.....don't have any of my manuals handy, I believe the ground and one of the power wires run in that harnes.
I'm traveling so I don't have any diagrams. There is a Common DIY Threads, second from the top. In that there is a link to a manual you can download.
You could start by testing the wires to both the AC compressor and the Cond fan relays. They both have a white wire that is "hot" at all times (fused from underhood fuse box-right/pass side). Check the other three to each relay, note which wire has what voltage/resistance to ground.
There are wires that run to AC pressure switch and radiator (pax side) fan. These are likely damaged and will require some wire splicing.
If you intend to DIY, download the 94-97 Accord manual from Online Manuals links in DIY forum. This has wire colors, pressure switch location diagram, etc.
and I thought more last night, but TX beat me to it. The AC Switch is under the battery on the AC line....I'd pull the two wires off the switch, one side should have 12v, the other should have zero resistance to ground. if not....note the wire colors at the pins, check the damaged part of the harness, find these wires and repair.
