97 accord heater valve replacement
97 honda accord
I was just wondering if anyone could help me locate the heater valve. I know what it looks like, but I have no idea where it's situated inside the engine bay.
Also, I may be wrong about what the problem is. Basically, there is never any hot air blowing out the vents. I believe the control **** works, because the heater was weakening as it was getting colder, and we had always maintained some control over the temperature of the blower. In my experience, this usually indicates a faulty HCV.
Anyway, any help would be greatly appreciated.
thank you.
thank you.
RE: 97 accord heater valve replacement
ORIGINAL: kurtdaniel
On most hondas, heater valves are in the heater core. This illustration may help you - http://autorepair.about.com/library/...bl303a-lib.htm
This problem can also be caused by simple cracked heater control ****, not actuating the stem the **** fits over. Pull **** off and check.
Also, the push/pull wire that actuates the heater core valvecan become disconnected under pax side dash.
You can manually actuate the heater core valve on the engine side of firewall to see if it move easily. If yes, then one of above should fix your problem.
NZXTInerTia
07-20-2012 03:06 AM
