97 accord non-vtec to vtec HELP
It's a 4 banger. I'm at work at will let you know the number on the PCM. It seems right 37280 something something. I the doner motor was just sitting around at the shop I had it done at. I am no longer aloud to go there. But if I could this would be alot easier. Thank you all for helping.
since i dont have the uhm vtec wiring harness there is no pin in a8 so i just ran a wire from the green/yellow one on the soleniod and just put it where the a8 pin is. then test drove it didnt work. but then upon close look there is another plug that has 2 pins inside it im not sure what is it.
P0B ECU is from a '96 non-VTEC Accord. VTEC won't operate with that ECU. To get VTEC to work you'll need a P0H ECU. This TSB lists ECUs for automatic '96 - '97 Accords:
Ignore that plug. It's for the VTEC pressure switch. The P0H ECU has no circuits to operate it. VTEC will work fine without it.
.pennybaker.com/ody/sb/SB%2001-012(dot)pdf
(add www to the address)
...but then upon close look there is another plug that has 2 pins inside it im not sure what is it.
Found this digging through my engine swap links:
37820-P0H-L01 - 1996 2 & 4dr KA/KL OBD2 F22B1 VTEC w/5spd trans
37820-P0H-L02 - 1997 2 & 4dr KA/KL OBD2 F22B1 VTEC w/5spd trans
37820-P0H-315 - 1996 2 & 4dr KA/KL OBD2 F22B1 VTEC w/Automatic trans
37820-P0H-L54 - 1997 2 & 4dr KA/KL OBD2 F22B1 VTEC w/Automatic trans
37820-P0H-316 - 1996 5dr Wagon KA/KL OBD2 F22B1 VTEC w/Automatic trans (only comes in auto)
37820-P0H-A73 - 1997 5dr Wagon KA/KL OBD2 F22B1 VTEC w/Automatic trans
KA = 49 state emissions
KL = California emissions
99accordf23a5
05-06-2014 12:51 AM
cd51994accord
01-30-2014 12:56 PM
94coupeaccord
02-07-2007 05:01 AM
37820p0ba70, 95, 97, accord, control, ecu, forums, honda, nonvtec, reddit, se, solenoid, transmission, unitmodule, vtec
