97 accord rack issues
Old 11-29-2009 | 07:36 PM
jscardino
Default 97 accord rack issues
im replacing a rack and pinion on a 97 accord 4 cyl auto. are there any tricks to getting the pressure line and return lines off or even accessable. any tricks would help
Old 12-15-2009 | 05:51 PM
hondadude's Avatar
Hope this isn't too late to help;
BE SURE TO CENTER AND LOCK THE STEERING WHEEL.
Air bag reel under the steering wheel can be damaged
there is a cover plate over the line fittings, use line wrenches.
With the steering wheel locked/centered, take careful measurements from the center of the ball joint studs to a fixed place on the rear subframe; also count the tie rod end threads.
frankenstein69
12-28-2014 01:36 AM
Ineedhelp
01-22-2012 08:29 PM
jscardino
11-30-2009 09:08 AM
GOT BOOST
11-02-2009 09:32 AM
RoXeTTeMaN
05-14-2007 02:08 AM
