97 accord shift problem
Old 06-02-2009 | 05:25 PM
nehring8
Default 97 accord shift problem
My 97 accord automatic transmission slips between shifts, in a 4 cyl V-Tec. When it is ready to shift the RPM's increase anywhere from 300 to 600 RPM (based on load) before shifting(it almost seems that it takes too long to shift), when it finally shifts it shifts in very solid. It only seems to do this from 2-3, 3-4. I really cannot believe that the whole transmission is bad but does anyone know what this may be.
Old 06-02-2009 | 05:49 PM
I would change the tranny fluid using Honda ATF. Since ~1/3 of the fluid drains, you should drain, refill, drive around for a few miles. Repeat 2 more times to exchange most of the fluid.
When you initially drain, see if the tranny fluid has excessive metal shavings.
You may also want to unbolt the solenoids on the tranny and clean the solenoid and screens.
Old 06-02-2009 | 06:30 PM
nehring8
yeah, that's what I thought too, tried both. also jumpered the solenoids to make sure they were actuating correctly. any other ideas?
rydnlow1120
11
11-11-2015 06:29 PM
325wc
11-04-2009 11:48 AM
foxylady23
05-14-2008 01:50 AM
thunder_x
10-24-2007 11:26 AM
