97 Accord sluggish at startup
Old 01-27-2007 | 05:39 PM
DawgatAuburn
Default 97 Accord sluggish at startup
I have a 97 Accord with about 125,000 miles on it. It's a fourcylinderwith automatic transmission.The last couple of weeks when I have started it up and began moving, the car is extremely sluggish in the lower gears. Feels like is is not getting enough power, and shifting is slow.After 30 seconds or so, full power kicks in and everything is fine. This only happens after the car has been sitting for a while, like overnight or all day at work.
A buddy of mine thinks plugs and wires. Any other ideas?
Thanks in advance.
Old 01-27-2007 | 09:11 PM
drummer1279's Avatar
Default RE: 97 Accord sluggish at startup
plugs, wires, needing an oil change, clogged fuel system, trans fluid needs changed, etc...there are a few possibilities.
Old 01-27-2007 | 09:21 PM
hondadude's Avatar
have a look at the spark plugs, maybe a throttle plate clean.
Scrub out the ring of crud around the throttle plate
Old 02-20-2007 | 08:41 PM
maro's Avatar
Where is this located??? I'm a bit sluggish too.
Old 02-20-2007 | 08:48 PM
sir_nasty's Avatar
remove the intake hose from the engine, the part that it's connected to is called the throttle body, that's what the picture is of....
Old 02-21-2007 | 02:47 AM
maro's Avatar
thanks
lilytek
11-15-2009 07:56 PM
sailaja_giri
05-24-2008 06:27 AM
dsmulla
03-05-2008 10:00 PM
tony11
06-05-2007 04:31 PM
Jessab
03-24-2007 07:51 PM
