97 Accord stumble on acceleration and has Crank Pos CEL
Old 08-29-2014 | 09:57 PM
snowcat021's Avatar
Default 97 Accord stumble on acceleration and has Crank Pos CEL
I'm going to try and help a friend that has my old 97 Accord EX 2.2. It stumbles, sometimes stalling, going up hills or under hard acceleration. He had a CEL, so he when to autozone and they told him it was a crank shaft position sensor. This sensor is only a year old, so I would not expect it to be bad.
If the timing belt jumped a tooth, could this cause the sensor to throw a code and the engine to run like this? I have seen the other treads about the egr port cleaning, but since he has a crank sensor code, I'm thinking it might be timing related. If it is the sensor, and the timing belt is right, can I get swap the sensor out without removing the timing belt? I know I'd have to remove the crank pulley.
Old 08-30-2014 | 10:21 AM
It would be nice to have the actual code number - sometimes the "descriptions" of the code(s) from someone else gets confusing.
Old 08-30-2014 | 06:56 PM
snowcat021's Avatar
I'll have him get the code number
Old 08-31-2014 | 08:42 PM
snowcat021's Avatar
My friend lost the code, but will get it re-scanned tomorrow. Sorry this is taking so long
Old 09-01-2014 | 10:22 AM
No problem - again just want to be sure to try to give proper information and I've learned in the past that getting/going on the "parts store description" of the code might not always be a good idea.
Old 09-02-2014 | 06:49 PM
snowcat021's Avatar
Okay, the code is P0335.
Old 09-02-2014 | 07:38 PM
snowcat021's Avatar
Say there is a bad connection to the sensor...would that alone make the car run poorly, or am I looking at two different problems?
Old 09-03-2014 | 02:21 PM
P0335 = crankshaft position sensor low input
Yes, I think that might be caused by a bad connection at the sensor. Down near the crankshaft pulley, the sensor wires run along the back edge of the plastic lower timing cover.
Dirty/loose/corroded pins in that wiring plug? Rock hit the wire & broke through the insulation? Anything like that...
Old 09-03-2014 | 04:25 PM
snowcat021's Avatar
The connector looks fine, and the wiring. Drove it, and it seemed fine. Drove it again, and stared acting up again. Maybe it is a bad sensor. So the sensor itself will make the car run bad?
Old 09-03-2014 | 10:41 PM
YeuEmMaiMai's Avatar
was it a Honda sensor or a aftermarket one?
