97 Honda Accord LX 2.2 4 cylinder VTEC
I have no spark in my plugs, but everything checks out all the way up to the distributor. Had put new plugs, wires, cap, distributor rotor, Ignition coil, everything still no spark. Started with a bad downstream O2 sensor that I replaced, now it won’t fire. Last time I drove it, it backfired a couple times and shut off, hasn’t started since. Timing belt is ok as the distributor rotor turn while cranking. Have no idea what it could be please help me!!
You've replaced a lot of parts, so there is always a risk that a new part was bad out of the box.
Here is a link on testing honda ignition system using a test light. The LX setup is a bit different, because the coil is outside of the distributor. You would have to back-probe the green wire to the coil connector to test for the igniter switching to ground.
Krsheffield
07-17-2019 09:59 AM
Chris Jameson
02-19-2013 06:39 AM
navdeep
04-11-2012 04:22 PM
PJ_STYLES_95AccordEx
10-24-2007 09:58 PM
