97 honda accord SWAP!
Old 05-08-2011 | 08:46 PM
hondahead23's Avatar
Default 97 honda accord SWAP!
im look into doing a jdm h23a dohc vtec swap in my accord what would i have to do to ensure a clean swap could i use my f22 tranny since its brand new, is the wire harness interchangeable, what motor mounts would i have to change
Old 05-08-2011 | 09:09 PM
Your f22 transmission will work. You will use your f22 wiring harness and modify it to work. You can either grind the passenger engine mount to work or buy a hasport one.
Swapping in a h23a is pretty much the same as swapping in a h22a just need a different ECU
Old 05-09-2011 | 08:48 AM
what wires on harness have to be modified
Old 05-09-2011 | 10:53 AM
Well since your car is nonvtec you would have to add vtec. If I remember correctly you would have to swap out the oil pressure switch, rewire the crank position sensor, and distributor.
Jrmemo
01-27-2013 07:41 PM
hondahead23
05-09-2011 08:55 AM
mfskarphedin
06-06-2010 09:33 PM
dswiz1984
10-17-2008 09:10 PM
Quick Reply: 97 honda accord SWAP!
