97 Temp issue
97 Temp issue
Hi i have a 97 Honda accord that gets a spike in tempreature after driving 70-80 miles, i did a pressure test for leaks and bled the bleeder valve i think my radiator is not circulating the coolant properly what do you think?
97 honda accord gets hot after driving 70-80 miles.
Is the temperature spike happening while driving or is it mainly when at stops, e.g., at idle? Does the temp. drop when driving, where moving air cools helps cool the radiator?
If the car has A/C, are both fans (A/C condenser fan and radiator fan) operating when there is the temp. spike?
Bleeding from just the bleeder valve (by itself) is generally not the recommended procedure. If the thermostat didn't open during the process, there may still be air pockets in the cooling system.
Generally, the radiator cap should be left off or just put on loosely, then allow car to get to operating temperature where the thermostat opens. It is after the thermostat opens that most of the air purging from the cooling system happens.
When was the last time the rad cap and thermostat was replaced. I do not like throwing parts at an issue but both of these are cheap and should almost be considered "wear items" IMO.
Some parts stores can test the rad cap.
Is the temperature spike happening while driving or is it mainly when at stops, e.g., at idle? Does the temp. drop when driving, where moving air cools helps cool the radiator? Yes
If the car has A/C, are both fans (A/C condenser fan and radiator fan) operating when there is the temp. spike? Yes
I can start the car let it idle for 30 minutes get in drive about 30 minutes and the temperature spike only happens when i hit traffic. I will put the car in neutral rev up the engine and the needle starts dropping and of coarse when i'm stopped the needle goes back up.
Replaced the thermostat and purged the air out of the system.
Just noticed today that both my cooling fans are squeaking and not coming on when sitting on idle after the car warms up, they may be failing and not coming on when suppose to. The radiator fan switch is unable to communicate with the fans. Going to replace the cooling fan, Thanks will let you know what happens.
anti3025
04-01-2012 11:33 PM
raf105
09-28-2007 02:55 PM
97, ac, accord, cooling, drivers, flush, honda, hot, move, radiator, recommended, replacement, temp, temperature, thermostat
