97 vtec 5 speed backfires and dies
Old 08-01-2012 | 03:38 PM
jasonboes's Avatar
Default 97 vtec 5 speed backfires and dies
okay. I drove this car today about 20 miles it ran perfectly. On the return trip it started to backfire and would loose all power. Also when it was running well it felt like the power was lost on the top end. Almost like the timing wasn't advancing. It has new timing belts just done.
Old 08-01-2012 | 04:28 PM
jasonboes's Avatar
I did get P0108 for a code on the reader. But it has a new map sensor in it.
Old 08-01-2012 | 07:32 PM
clear the code. Then when the car starts having a problem, check for codes again.
Did the car run ok right after the timing belt change?
Old 08-02-2012 | 12:45 PM
jasonboes's Avatar
It had an issue with a ground. But then it ran fine. Someone removed the intake to change the TPS. So I am thinking there might be a vacuum leak. I am going to check that on Monday.
5TWENTY3
11-18-2014 05:30 PM
Joe Johns
11-11-2014 11:56 AM
jrock24
02-12-2014 04:15 PM
Nicolai Hobbs
07-12-2012 05:44 PM
942.2EX
08-25-2010 04:50 PM
Quick Reply: 97 vtec 5 speed backfires and dies
