98 accord door lock issues
RE: 98 accord door lock issues
You're absolutely right, I think I got a bit carried away as I was reading the replies. Haven't taken the door apart yet, was going to do that omorrow. The thing that's really weird is that when I first goet the car a week ago, everything worked for about 3 days, then all of a sudden, the drivers door lock started acting odd.
I have the same problem..
I disconnected the ground for the right side windows.. while replacing the cabin air filter behind the glove box.
Now.. My driver door main lock/unlock does not work.. all four door locks click" but will not move
fully up or down.
My remote will not open the driver side door. or any other... ON cold mornings, I do get the drivers side to open..
I have tried the wiper setting to half.. Key on, (dash lights on) then off and tried the driver side switch.. NoGo.
Tired pulling the 7.5 Amp fuse under hood pasenger side.. (read this was the wiper reserve) for 15 sec. and re-installed..
Driver switch still does not work.
Any time I do try the remote, or door switch.. I get the clicking sound at each door and under the glove box too. but still do not work.
I have re-programed the remote with the (four-cycles of the ignition) and then the remote transmitting.. It works okay, cause I get the clicking sound and the trunk does open.
All I can guess would be the third of three control multiplexer under the glove box, the one that transmitts the final cammand to actuate the door soilinoinds up or down.
Any suggestions?
ElMe
fully up or down.
Any suggestions?
ElMe
It worked~!!!!!!
So this is the main reason I signed up for this forum. Thanks for saving me a headache.
Had my transmission rebuilt, they had to charge my battery, now my power door locks are not working,when trying to unlock doors only, rear driver side unlocks, but I hear a click in all the other doors but they won't unlock, only rear driver's side locks and unlocks, what could be the problem and what should I do?
#20
honda accord, door locks
Ok, will certainly do that, because I suspect that he didn't connect everything when he charged my battery, or was fixing my transmission, because, when I try the trick to reset, with intermittent it doesn't work, also were it says maintenance required, it has the battery light on also, the gas icon, plus when car doors are closed, the dash says there open.
pmay805
03-16-2015 10:41 AM
frankenstein69
12-28-2014 12:36 AM
HateThisHonda
09-19-2013 09:45 AM
Doublel
03-11-2013 07:57 AM
