98 Accord ECM/PCM testing
Hi I'm Steve, new here. Betsy, my 98 accord 4 dr auto 2.3 also new here. Ive been a mechanic for 40 yrs.....popped the intake off to clean EGR to make sure i passed smog, put her back together, ran awesome for a day or two. The interlock solenoid wouldn't let me take it out of park so i used a screwdriver to release it. no CEL light. Drove it and the trans wont up-shift so i i put it in 1st take off and it manually shift to 2nd...it works no 3rd or 4th. i bring it back and scanned it. I have OBD2 software on my laptop. comes back with 2 codes. P1106 Barometric and P1753 lock up sol. so i replaced the lock up sol. and the dual linear sol. for good measure. Didn't fix it......yet. so i looked into the baro problem and troubleshooted it as per Honda's diagnostic manual. now i'm to the part where i swap a known good ECM for this one. I visually inspected the inside and inside bottom ....nothing, looked great no burns or arcing.So since the baro unit is in the ECM what I want to know is can i test and repair this one if faulty and what resources are there available to assist me. i have ocilliscopes and I build and repair computers , is it possible to repair ? Then i'll let you know about the unrelated trans problem.
Not many people have equipment or your skills, so it may be hard to find a repair guide.
If you can find the BARO sensor soldered to the PCM, you may find a cracked solder joint that you can try to repair? I'm not sure if you can easily find that component on the web to try and replace. There aren't any wires you can test to identify the actual problem, since it is on the PCM board.
AccordMeister
05-06-2009 06:57 AM
