98 Accord Front Wheel Bearing Replacement
Old 06-07-2009 | 12:06 AM
emcom
Default 98 Accord Front Wheel Bearing Replacement
Need help on my 98 Accord!
I need to replace front wheel bearing.
Does anyone have a manual or instruction to remove and replace the bearing? I never have done it before.
I'd like to know how hard the job is. Is it worth to do it myself? Or just take it to mechanic?
I also like to know the bearing will come off easily from hub housing. Do I need a presser to remove and install new one into hub?
I would appreciate any response. Thank you
Old 06-07-2009 | 12:55 AM
Fuse's Avatar
Thy press in you need a press yes = hard to do.
Books at
www.hondatech.info and some other sites if you search hard.
Old 06-07-2009 | 03:18 AM
makman
Arrow 98 Accord Front Wheel Bearing Replacement
Unanswered questions | Most-recent questions |
Reference library ... How do you replace rear wheel bearing 1998 accord? How do
you replace a rear ... Is it easy to replace wheel bearing for honda accord 2000
yeah, thanks for that amazing insight. I removed the spam from your signature...
Old 06-08-2009 | 07:44 AM
You can remove the steering knuckle, & take it to a shop for them to press out the bearing.
Old 06-08-2009 | 11:02 AM
00AccordLX5spd's Avatar
Registered User
In other words: you cannot completely DIY yourself. You need a press to remove the hub.
Removing the steering knuckle is not too hard to DIY. It would save you some $ for labor. But you will need a punch to unstake the 56mm axle nut *Correction: 36mm*. Anyways it's not too easy to unstake that sucker. I thought I was going to ruin my axle nut when I did it. Plus you need a socket big enough to fit on there. I had to pay like $15 or $20 for one lousy socket.
Old 06-08-2009 | 11:45 AM
I don't own a 56mm socket, so I don't think that's the right size (I used to own a 98 Accord). Maybe 32mm or 36mm?
Harbor Freight sells presses like you could use for this, but most DIY mechanics don't have one. So we just assume...
Old 06-08-2009 | 12:11 PM
Registered User
Dang...you're right,. It was 36mm. 56 would be huge haha! It's monday morning here in Mississippi.....
Old 06-08-2009 | 12:13 PM
finch13's Avatar
Yes, the axle nut is 36mm. I bought a wrench at Northern Tool (or Harbor Freight) for less than $10.
Old 06-08-2009 | 12:31 PM
finch13's Avatar
I've brought a hub to a shop to get bushings replaced and was charged $40 to install 2 bushings, I supplied the parts and it was a friends shop (I don't think I got a discount). I'd expect to pay at least $20 a corner to get the pressed out and in.
joenintiesc
04-14-2013 08:29 AM
3064datazz17
06-28-2012 10:16 PM
Doug Grellner
05-17-2012 08:20 PM
ryandamartini
08-15-2011 10:18 PM
ScottSoSlick
03-18-2009 04:28 PM
