98 Accord Hesitation when cold
I have the 4 cyl. EX model, 155K mi. When the car is "cold", i.e. engine has warmed to normal operating temperature, then the car hesitates when the gas pedal is pushed down. Then after a second of "nothing" it lurches forward and gives you whiplash. I've had it to the dealer a couple of couple of times, and they couldn't seem to repeat it, nor could they find anything wrong with it. This problem doesn't occur every time, but about 70% of the time. This problem has lingered on now for several years. I believe I've had the manifold cleaned, timing checked, spark plugs & wires changed, etc......
Any ideas?
Any ideas?
RE: 98 Accord Hesitation when cold
there is a bulletin on this 01-004 applies to all 98-00 accords 4 cyl.........your symptom sounds just like that
ask the dealer if they performed the work as per the bulletin on your car //
d0n
12-10-2014 07:42 AM
1998, 98, accord, car, cold, gas, hesitates, hesitating, hesitation, hessitation, honda, pedal, pettle, pressed, problems
