98 Accord Horn Problems
Hi folks. My horn has stopped working - I can hear the horn relay clicking (also swapped in another relay which also clicked) but the horn itself does sound. Any ideas? Is there a horn fuse I should be checking (I couldn't find one listed on the fuse map inside the car and under the hood.
Thanks for your help.
RE: 98 Accord Horn Problems
chk fuse # 47 underhood fuse box 20 amps.......if it is ok, locate the horns and chk to see if you are getting power at the blue/red wires.. if not you might have a bad horn relay ..which is also located in the underhood fuse box
Thanks for the reply. I checked the underhood fuse box, but there's only a dozen or so fuses and none are numbered #47, Also none of the descriptions on the fuse map says anything about protecting the "horn". I pulled everyfuse anyways and they all appear to be okay. Is there more than one fuse box under the hood? Neither of the two side-dash-fuse-boxes say "horn" on the descriptions either.
Thanks again for your help
wish234
03-04-2009 10:14 AM
