98 Honda Accord A/T-No key, starting motor runs
Old 04-23-2013 | 01:29 AM
primemover's Avatar
Default 98 Honda Accord A/T-No key, starting motor runs
-No key in the ignition
-New (known good) battery installed
-Positive Cable connected
-When Negative placed on post .... starting motor runs continuously
-Plunger does not engage (fortunately) - so engine did not turn over.
Background:
-This car had been stored for ~three years, with battery removed.
-The car has been stored in a garage - dry and temp never below 35 F degrees.
-The car operated fine before the car was stored, especially the starter - no problems.
-No one touched/tampered with the car in storage.
-I have driven 99% of the miles (~96K) and it has been serviced properly.
-Cable connections @ battery and starting motor are clean, corrosion free and tight.
What happened?
(my ~guess~ is a relay is closed that should be open. But please ignore my guess, OK?
Old 04-23-2013 | 05:40 AM
For starter to turn the solenoid on the starter must be shorted closed. It may be frozen from rust or dried oil. Remove starter and clean/check the solenoid and starter bendix movement, or replace the starter.
csh217
06-17-2014 05:53 PM
corlyf
09-12-2012 11:30 PM
Injun Joe
05-26-2012 07:10 AM
chris30721
01-06-2011 08:06 AM
Accord Pete
01-31-2010 02:50 PM
Quick Reply: 98 Honda Accord A/T-No key, starting motor runs
