98 SRS Light
98 SRS Light
This is for my moms 98 Lx. The SRS light came on and I thought it may have been when the mechanic swapped her ignition switch out since typically you disable the SRS when working around that area.
I checked the fuse and it was fine. Her mechanic said that there is a sensor under the seat that often fails.
How do I pinpoint the problem? And how do I do this without setting off the airbags?
Not much tinkering, I just wanna take a look to see how extensive the problem is. Do the 6th gens have problems with the SRS often?
