98 V6 Transmission
#21
The OBD2 connector should be in that general area. It is typically near the plastic panel that covers the bottom of the steering column. It may sit slightly behind the panel. When sitting in the driver's seat, it should be to the left the steering column, but I am not 100% sure on this.
Try to get the codes read if you can. If not, then you should consider a used OEM part, because the IAC is not a common problem from my experience on accords. There is always risk for used parts, but I think there is also risk on very cheap aftermarket parts as well.
#22
Correct, but it's way to the left of the steering column. Look for the OBD-2 plug closer to the door, and closer to where the dashboard curves upwards. More like above the driver's left knee, not close to the dead-pedal.
#23
OK, JimBlake, thanks for the info, I'll check again and report.
By the way, I had a 900SPG for 20 years but the tranny died on me (another one....) and I'm selling it for parts now... :-(
Anyway, I really like the Accord coupe look too :-)
#24
Hey guys,
Another dumb question probably but I've been reading the FSM and can't be 100% sure that I'm right:
The crook dealer I got the car back from left a few "surprises" for me I guess... For example, in addition to the idle problem, my fans don't come on when they should so I wanted to test the circuit with the "paper clip" procedure but I can't seem to find the fan switch....
I found something but I'm not sure it's the right one. Should be on the throttle body, right between the coolant hoses close to the AIC Valve, right?
Thanks again for all the help.
#26
Don't short anything until someone on here verifies that the 98 V6 has a fan temp switch like the older accords.
There shouldn't be anything plugged into the obd2 port unless someone left their obd2 bluetooth connected to the OBD2 plug. The OBD2 connector should be the only trapezoid shaped connector in that area.
#28
Hey guys,
Right JimBlake, I am in France and I bought the car in Switzerland... Not sure if the OBD2 plug is available here but it looks like all the coupes were built in Ohio and then sent to different countries, at least for Europe.
Anyway, I worked with a tech friend (20 years in industrial maintenance: electric, electronic, hydraulic,...) and we cleaned the AIC: idle is fine again.
Then we disconnected one part at a time to try to narrow the causes.
We spoted four parts that my friend thinks I should change: valves B & C and the 2 transmission speed sensors (mainshaft and countershaft). He says that, even though they were tested good (impedance, voltage,....), they are 20 years old and might not function as smooth as they should.
Fixing the idle makes the car a lot smoother now of course, speeds are still shifting a little harsh but nothing compared to what it was, only problem left seems to be late shifting from 1st to 2nd (up and down) but during all my oil drains, I had once and for 2 days a butter-smooth transmission, I had to have my hand on the wheel to notice that it shifted. So it IS possible :-) and I'm going to try to restore it this way.
Any ideas about what we found, what are your thoughts and advice?
Thanks all for your help.
