98 will not start after getting new battery
Old 09-12-2010 | 01:56 PM
Mzaman311's Avatar
Default 98 will not start after getting new battery
The dash and power everything comes on but when i crank it, it just dies, doesnt even try to turn over. The alarm system will automatically go off as well. Any ideas?
Old 09-12-2010 | 02:48 PM
Double check the neg. cable. Sounds like something isn't making a good ground. Was this happening before or after replacing the battery......could be something else if this was before.
Old 09-13-2010 | 02:10 PM
Mzaman311's Avatar
Bingo. Thank you, definitely saved me alot of grief. Guess i should get the cables that lock onto it
Old 09-13-2010 | 05:40 PM
The starter motor takes a lot more power then everything else combined. If any connection is weak, most of that stuff will work OK but the starter won't.
It's always good to check both ends of all the battery cables for being loose, dirty, or corroded.
Finkster
09-29-2014 03:22 PM
cmburns9987
11-05-2009 09:57 AM
smoletx
02-20-2008 11:13 AM
matrix2004
09-18-2007 12:24 PM
