99 accord
Mr Omar,
I got two videos for you:
1) One I made on a ATF change. I urge you to only use Honda ATF DW-1. 2007 Honda Accord V6 Automatic Transmission Fluid ATF Change/ Flush - Drain and Refill - YouTube
2) One from Youtube by an experienced car mechanic/tech. How To Change Honda Automatic Transmission Fluid - YouTube He does it on a older Acura from the 90s. Should be similar.
Ignore how the 2nd video says to use about "3 quarts." I urge you to measure the amount of ATF that comes out and put exactly that amount back in when putting the new fluid in. I see a lot of posts of guys doing it by the book and their tranny goes to crap, and I assume it is because of shorting the tranny by a quart or two when you do multiple drain and refills and short the tranny for what it drained out.
