99 accord lx v6 starting problem..
Old 09-06-2005 | 06:36 PM
quack31
Default 99 accord lx v6 starting problem..
I have a 99 accord lx v6. the problem i'm having is trying to start the car. It happens every other day. When I turn the key, it gives me the grinding nose but it won't start up. After a few min, if i'm lucky it will start up. Once it starts up, it runs perfectly fine. I have an viper 791 xv with auto start. I've been told that it could be an alarm issue. Can someone help me out. Thanks!!
Old 09-06-2005 | 11:20 PM
RTexasF's Avatar
Super Member
Default RE: 99 accord lx v6 starting problem..
It's possible, from your noise description, that the starter is turning but not engaging. Were it mine, I would have it checked out.
[IMG]local://upfiles/127/4010BF31EE1C4EB3A746216A5E1F33C4.gif[/IMG]
Old 09-07-2005 | 10:58 AM
accorddriverc's Avatar
sounds like the starter to me also
Old 09-07-2005 | 04:23 PM
quack31
thanks guys.. i'll go in and have my starter check up. I'll let ya know how that **** goes.. once again, thanks!
Quack Quack!
Old 09-09-2005 | 11:24 PM
quack31
i took out my starter in and had it checked out. the guy at autozone ran a test on it and said that the starter was bad. i bought a new one and put it in. the first few crank, the car started up with no problem. minutes later the problem came up again. now i don't know what the problem can be. totally lost. can anyone help?
Old 10-02-2005 | 06:17 PM
vincentcoelho
Hi, Right now I am having exactly the same problem with my v6 1999. The mechanic has spent unlimited hours troubleshooting without success. He has replaced the battery and the alternator. The problem usually occurs when the car is seating for a long time in the sun.
I live in florida and the problem shows when the car seats for like 6 hours. The mechanic is planning to replace the main relay tomorrow and I am planning to take the car to the dealer as a next step because I am 100% sure that the dealer knows exactly where the problem is.
Have you solved your problem yet?
Old 11-09-2005 | 08:49 PM
vincentcoelho
Hi, The problem similar to my car I ended up taking to the dealer. They replaced the main relay and the problem was gone. Everyone was guessing a different thing like gas pump, alternator, battery, etc. But this is it ... just replace the main relay.
Old 02-05-2007 | 03:36 AM
jumps0913
I know kinda old post...but what is this main relay
Thanks!
Old 02-05-2007 | 05:07 AM
The main fuel relay consists of two relays that rely on the position of the ignition switch and starter signal as an imput. The relay powers the fuel pump and the injectors (via the injector resistors) and sends a signal to the ECU. The clicks that you hear when you turn your key to ON are from that main relay.
The tegger.com site that is set as a TOP post describes it in good detail and has a lot of other good information on it.
http://www.tegger.com/hondafaq/mainr...ion/index.html
Yamasaki
11-05-2011 09:19 AM
mlaccord
07-31-2006 12:22 AM
babylon888
02-16-2006 02:08 PM
cyurgeles
01-21-2006 10:36 AM
rev2ninetyper
11-14-2005 04:06 PM
Quick Reply: 99 accord lx v6 starting problem..
