99 Accord Spark Plug Tube, Pulled some piece out. Not sure what it is.
In between the "X"s in your photo is a corner/edge. Put a little on that corner. It's less important to cover the flat surfaces with "X" as long as you get some on that square edge. Just a little is needed. Too much will ooze out & harden into globs inside your engine.
The rubber corner is not "sharp" enough by itself to get into the seam between the 2 metal pieces. (the seam between the head itself & the cam-bearing cap)
Now for those tube seals...
Make sure you haven't scratched up the metal surface with that screwdriver. That would make a leak path. If you have any scratches (especially deep gouges) use a little bit of grey goop there too.
This looks worse than it is due to bad focus but would it need the goop treatment and if so would I dry the goop before installing the seal because I was planning to help that process with a coating of oil. Note all I did here was touch screwdriver to rubber and tap until it fell out, don't know how that could scratch.
Yes. The brightest aluminum is where the seal rests and the area above it is the walls that hold the seal. So just oil and not sealant + oil. Good to know. I was worried it would leak. Thanks.
kain9i6
03-16-2012 03:19 PM
