99' Accord Timing belt
Old 05-07-2012 | 11:28 PM
crosed's Avatar
Default 99' Accord Timing belt
Hi everybody..
i want to know about change the timing belt..
if i want to change,what parts need to change too?
1.timing belt
2.balancer belt
3.water pump
and i confuse about the seal and gasket..
what seals and gasket i need to replace?
Old 05-08-2012 | 01:06 PM
First read the DIY forum which answers most of your questions.
Suggest you replace tensioner idler parts (bearings).
Many replace valve cover and spark plug tube seals since valve cover must be removed or at least loosened.
You only need seals that are replaced. Inspection of seals is suggested to determine which are leaking and only replace if leaking. Crankshaft, camshaft, forward balance shaft, and rear balance shaft cover (oring).
Largest challenge is harmonic balancer (crankshaft pulley) retaining bolt removal. It is very tight and may require special tools, unless you have a powerful air impact wrench and heating torch. Again, there are lots of threads on this subject for reading using search features.
A shop manual for your car is recommended. Honda OEM is best either e-manual (check ebay seller automanualsource) or hard copy (helminc.com).
john_pyro
08-04-2019 06:06 PM
5.0stang
04-23-2013 07:37 PM
ss485
02-23-2011 09:18 PM
Jay 3rd
02-17-2008 11:54 PM
Tony1M
04-01-2007 06:42 PM
