99 accord transmission slip:Moved To Correct Forum
Old 07-14-2011 | 01:06 PM
Mackie's Avatar
Default 99 accord transmission slip:Moved To Correct Forum
I'm the new guy, just finding this site today, please excuse my ignorance and transgressions.
My 99 accord, automatic transmission, V6, with 212K miles runs great, but recently the transmission slips. I have totally flushed the oil by dropping the old oil and adding 3 new quarts four times.
Sometimes it works fine, sometimes it will work if I start in Low, but will not upshift manually or automatically. After stopping for a traffic light it may not go. (I have been receiving one finger salutes for this.) It seeme to work better if the oil is hot.
Is there something I can do without spending more than the car is worth? Or, am I finished and have to limp to the junk yard? Many thanks!!
Mackie (99 Accord, V6, Automatic Xmission, EX?)
Old 07-14-2011 | 01:47 PM
Hi Mackie..This might get answered here in this correct forum much faster, that's why I put it here...
Old 07-14-2011 | 01:48 PM
By The Way...I see your Brand New ...so Welcome to the HAF...
Old 07-14-2011 | 02:54 PM
Mackie's Avatar
Many thanks!!
Old 07-14-2011 | 03:19 PM
If the D4 light starts flashing, or it stays on when you shift to park, you can get the codes read from a parts store like autozone. Post the code number on here, like P1234. The descriptions can be vague.
The 98-02 V6 accords were known to have automatic transmission problems, so your transmission may be on its way out.
Did you use the Honda automatic transmission fluid? Was there a lot of metal shavings in the fluid you drained out?
Old 07-14-2011 | 11:49 PM
Mackie's Avatar
Thanks for the help. I used Honda atf. Fluid looked clean.
Old 07-15-2011 | 12:34 AM
Get the codes scanned just to be sure that the problem is not with a sensor or something simple.
Old 07-15-2011 | 08:40 AM
Mackie's Avatar
Thanks! I'll do it.
Devon7234
02-06-2013 08:57 PM
jon.cook19
12-27-2012 05:25 PM
Jdmda91
05-14-2012 06:29 PM
wish234
05-06-2009 11:47 AM
rloden
04-24-2007 01:08 AM
