99 Accord trouble starting
Old 08-17-2011 | 10:20 AM
JOEKIR's Avatar
Default 99 Accord trouble starting
99 Accord LX 2.3L AUTOMATIC
I just replaced the Fuel Pump and the Main Relay. I purchased both the relay and the pump from local parts store. After I changed them, it now takes a few seconds for it to turn over when trying to start. Normally only when it has been sitting for a few minutes. I was having issues with the car dieing on my while driving. Thought it was the fuel pump and relay. After changing both, it still died. I took it to the dealer, they said it was the ignition switch (covered under recall for a second time) and the new relay. They replaced the new relay again with a honda part. (1 day after I replaced it with the generic version). Car still take a bit to turn over. Is it possible that I am having fuel pressure issues from putting in the new fuel pump? If so how to I correct it? Possible air in the lines? If so, how do I bleed the lines?
stevwil41
11-03-2011 10:36 AM
louisvilleslugger
10-04-2011 10:45 AM
engtaz
06-10-2011 07:52 AM
dametalone
07-13-2010 08:44 PM
joeeeee
06-27-2007 11:30 PM
