99 accord would not start.
#41
The brake code bypasses the need for immobilizer system communication between the receiver unit and ECM/PCM. Therefore, when you turn the ignition to START or ON, the ECM/PCM will ground the main relay coil and the fuel pump will continue to receive power.
Without the brake code, the ECM/PCM will need the proper immobilizer receiver signal before it will ground the main relay, to turn on the fuel pump.
#42
[QUOTE=redbull-1;353718]The brake code bypasses the need for immobilizer system communication between the receiver unit and ECM/PCM. Therefore, when you turn the ignition to START or ON, the ECM/PCM will ground the main relay coil and the fuel pump will continue to receive power.
Thanks again. I understand now what the brake code does. Car still started this morning. Do I need the security or not? Car is 15 yrs old 210000 miles body is exceptional. I want 3 hundred thousand plus. this is my daughters car always serviced. Just need to know if ECM/PCM will disable car again. My understanding on brake code was 1 to 3 starts then it would disable thanks.
#43
Normally the brake code doesn't allow the car to be started that many times.
An October 2001 Honda Service News article mentioned some replacement ECM/PCMs are programmed to give 10 free engine starts before you need to use a programmed ignition key. These free-start ECM/PCMs are intended for the production line, but occasionally, they may get put into parts stock by accident.
Several possibilities:
Does the indicator (1) comes on steady (2) comes on for a few seconds and goes out or (3) something else?
- Entering the brake code somehow got the ECM/PCM to communicate with the receiver unit and recognize the encoded signal again. -- In that case, the no-start issue is gone.
- The ECM/PCM now has a strange glitch and gives free starts without restriction.
- If you have not started the car more than 10 times, it may not start after the 10th time without a programmed ignition key or the brake code needs to be re-entered.
#46
As I maintenance tech I had to keep looking was not going to trust car. After looking at post with picture of transponder I decided to open up steering column connection was not clicked in. I'm relieved sure it was issue all along. THANKS to all.
Uberpippi
03-23-2015 06:32 PM
Jeffrimerman
03-19-2010 08:11 AM
