99 brake hardline replacement
Hi all.
I have a 1999 EX coupe V6 AT that I need to replace some hardlines in. I already replaced the hardline that runs from the ABS module to the driver front brake hose. After bleeding the brakes and getting ready to test drive down my driveway, I noticed the other brakelines in the same clip are also rusted in the same place and not holding fluid/pressure. These run from the proportioning valve to the ABS module, along the firewall. I ordered 46378-S84-A50 Pipe Y, Brake and 46379-S84-A50 Pipe Z, Brake from HondaPartsNow. The only problem is the lines I received don't seem long enough. They are maybe 2 feet long, but definitely not long enough to wrap around the firewall from the driver's side to the passenger's side. Am I reading the diagram correctly? Did I just get the wrong parts sent (I verified the part # of what was sent matched the diagram). The diagram isn't super clear, but the proportioning valve and ABS module are definitely on opposite sides of the car. Any advice?
