9th Gen Brake Question
Old 06-22-2014 | 12:57 PM
bayn8v's Avatar
Cool 9th Gen Brake Question
Recently upgraded front rotors to a set of slotted. With only 10K on the used set I was thinking about resurfacing and swapping those out with the non ventilated rears. They are the same diameter 11.1" Has anyone done this before? Or is it even possible? If nothing else I will be trying it in the coming weeks I will keep you posted
Old 06-22-2014 | 03:15 PM
shipo's Avatar
While I haven't looked at the Gen 9 disk setup, it is HIGHLY UNLIKELY your front rotors will fit the rear hubs and calipers.
Old 06-22-2014 | 09:40 PM
You already have them, so it doesn't cost much to try.
But I bet they won't fit.
Old 06-22-2014 | 10:34 PM
shipo's Avatar
I just looked the rotors up, not only do the front rotors have a larger diameter (293.00mm vs. 281.95mm), they are nearly three times as thick (25.0mm vs. 9mm) and will certainly not fit inside of the rear calipers, at least, not with anything but almost completely worn out pads, even then they'll probably grind against the bridge portion of the caliper.
Hot Brass
09-06-2020 08:15 AM
girobers
01-08-2017 10:00 PM
signaturechrome
01-19-2014 05:54 AM
JohnnySasakiMGS
04-22-2013 05:16 PM
