ABS light illuminated - 2000EX 4cylinder 5mt
Just changed the cabin air filter and now my ABS light is on. I pulled the 7.5am fuse on the passenger side fuse box for the ABS and put a new one in. I also disconnected the negative battery terminal for a couple of minutes and reconnected. I changed brake pads about a week ago and the reservoir was somewhat overfull. I sucked out some fluid tonight and the light is still on. Is there some way I may have shorted a wire when I changed the cabin air filter?
See following link.
DIY: SRS Codes and reading them. - Club RSX Message Board
I believe (not absolutely sure) the procedure can be used to extract ABS codes. ABS light will blink the codes. Codes are all short flashes w/ 10's digit separated from unit digit by 1 sec pause. So ffff-p-ff = 4-2.
Post your codes for followup.
I checked with Autozone and O'reilly's and neither had a scan tool to read ABS. So I dropped by the Honda dealership and they wanted $110.00 to hook up the scanner. I went to Harbor Freight and bought their scan tool for $107.00. Plugged it in and it came back with 15-1, which is right/rear speed sensor. I took off the wheel and pulled the sensor. Sprayed some PB blaster in their and wiped it. Reinstalled and pulled the negative ground for a few minutes and reinstalled. ABS light still illuminated, so I ordered a R/R Sensor from Rock Auto. That should take care of the code. I'll provide you with a follow up when I install it. Thanks for all the info.
I have had some success w/ removing wheel speed sensor, stuffing a rag into the hole firmly against the tone ring, and rotating the wheel to clean the tone ring. It doesn't take to much debris to reduce signal strength apparently.
