abs and srs light
Old 05-18-2005 | 02:20 PM
01hondaccordlx's Avatar
Default abs and srs light
my friend has a 97 accord lx 2.7 v-6. both his srs and abs light are on. is this common for the older v6's? is there a way to make them stay off aside from pulling the fuse. when u pull the fuse, the power windows dont work anymore. thanks
Old 05-19-2005 | 12:51 AM
Evlampius's Avatar
Default RE: abs and srs light
ORIGINAL: 01hondaccordlx
yes - even better when you pull out a battery - take all your problems away [:@] [:@] [:@]
theres 2 seperate problems and no it is not the fuses.
the ABS system detects an error and signalizing it by ABS light
the SRS system detects an error and signalizing it by SRS light
the only right/proper way to fix that is Connect the service computer to a car computer and check for the codes.
Repair/Replace parts as needed.
Teridian_II
09-10-2014 06:36 PM
93Accord2.2
11-07-2013 08:10 AM
JJC
03-13-2013 07:17 PM
brayner
02-12-2013 07:59 PM
Antiriad
07-06-2012 10:00 AM
