AC
Are you planning on recharging the system on your own?
If so, I would consider replacing all the o-rings in the system and use a lubricant like Nylog or an equivalent.
You should also consider replacing the receiver/drier, because your system has been open to air.
Make sure that you pull a vacuum on the system and the a/c system and make sure it holds the vacuum (no leaks). Then charge the system.
And I want to say "Thank you" for letting us know what was found and where you are going, too many times we never know the end of the story. Which menas I/we never really know if the advise worked....so please let us know if it all works out and good luck.
