AC blowing but not cooling down
Old 06-02-2013, 09:59 AM
It's hard to come up w/ a scenario for 4-7 v at the compressor connector. I assume battery is good, 12.6v or thereabouts?
Some suggestions:
1) Measure voltage at compressor relay where you installed jumper. It should be 12V.
2) If you still measure low voltage, find fuse 34 in underhood fuse box and measure voltage to fuse 34. Fuse 34 is on back row nearest the firewall at the "next to inside" or 4/5 position counting from outside.
3) If you still measure low voltage, something is wrong w/ battery, battery connections, or your volt-ohm-meter.
Sapowell84
07-16-2013 03:18 PM
JangoFren
05-27-2013 10:18 AM
BHoward711
04-12-2010 08:57 PM
shad9876
09-03-2008 05:06 PM
muibu
01-25-2007 05:47 PM
Quick Reply: AC blowing but not cooling down
