accessory toggle switch mounting area for 2001 Accord
i have purchased a new head unit, and it comes with a safty feauture that has a wire connecting to the emergency brake so you can not view video when it is not engaged. I was wondering where would be the easiest place to mount the toggle switch i will use to fake apply the emergency brake. i was thinking right beside the emergency brake, or under the steering column. also does anyone know the best way to remove that trim piece.
thanks in advanced
thanks in advanced
No it will not.
You should do some research on-line about how to bypass your radio.
For me I had to ground out 2 wires and then I updated the unit using some software I got online for free.
95Coupe_360
07-19-2013 12:31 AM
