Accord 2007 horn replacement
Old 11-15-2011 | 11:29 PM
khilji5's Avatar
Cool Accord 2007 horn replacement
How to replace the horn of accord 2007 , some time its started working and sometime stop, please let me know what is the exact problem. If there is any video or pictures it will really help.
Thanks & regards,
farhan
Old 11-15-2011 | 11:49 PM
In the common DIY thread on top of the gen tech help forum, there is a link to online shop manuals. There is one for the 03-07 Accords. I think that you should verify that you are getting voltage to the horn when the horn button is pressed before blindly replacing the horn itself.
I would unplug the horn electrical connector and test for voltage. If you have 12V, then replace the actual horn.
If you don't have 12V, then I would move to the relay and test. Finally, I would test the horn button on your steering wheel.
Old 09-17-2012 | 07:53 PM
i4getlots's Avatar
Default horn issue
i seem to have a similar problem except the horn works when i set the alarm. aka hitting the lock key twice on the key fob but not when i have the car on and go to press the horn button.
also do you know where the relay is located ?
i4getlots
09-21-2012 04:02 PM
AL40236173Z
04-10-2012 10:51 PM
sagdast
12-31-2010 11:41 PM
lalblue
11-25-2010 08:06 PM
spanishpete
07-25-2006 11:36 PM
Quick Reply: Accord 2007 horn replacement
