Accord 2012 (4cy) selected dashboad lights not lighting
Hello all,
The lights on the 6 dashboard buttons (see attachments) not lighting. Each button functions properly, it simply does not light. Checking the manual - yes I have the official manual - , I can not locate fuses for these dashboard buttons. Thoughts,ideas or suggestions.
Thank you,
Bruce
Thank you,
Bruce
One fuse wouldn't be dedicated to only those small lights, so a blown fuse would have multiple electrical components not working.
Most likely cause is a problem with the circuit board behind those buttons. Since the buttons work, I'm not sure if it is worth the hassle to disassemble and inspect or the cost to replace that circuit board.
