Accord 50,000 mile Maintenance Requirements
RE: Accord 50,000 mile Maintenance Requirements
Depends on what year model. This is in the DIY section: https://www.hondaaccordforum.com/ser...m_33323/tm.htm
A "tune up" (Spark Plugs, cap & rotor) don't need to be done on 2000 and newer Accords until 100k miles.
ORIGINAL: Rando
Any one have an online link to what I might have to have done on a 50,000 mile routine maintenance for automatice Accord? When shouldyou reallyhave a tune-up done?
Thanks!
Thanks!
you should input year and model in your signature so we can properly reply to your question
look at the link that 00accordlx gave you
Since you have not done basically anything ...you might want to replace ,, tranny fluid ,use Honda ATF-Z1, brake fluid, air+ cabin filters, tire rotation, coolant, oil + filter change ,depending on when you did the last one ..
03-06-2007 09:27 PM
