Accord 87 Carburetor
Hi...I'm a new member, can help me about size of carburetor primary and secondary jet (spuyer) ?
And for fuel injector spuyer now installed with mark 75, is that a standard size for my accord ?
Cause I feel fuel mixture is too rich and I will re-setting the size of carburetor spuyer.
Thanks
Thanks
I have never referenced the size of the jets.
There is an air mixture screw on the back lower drivers side of the carb.
It has a sealing cap/plug over the hole.
The easiest way to get the cap/plug out is to drill a small hole in the side of the channel, then slip a pick in and push the cap off.
89dxlame
03-01-2008 03:28 PM
87, accord, accord87, caburetor, carbeurator, carburetor, code, honda, karburator, main, mixture, primary, size, spuyer
