Accord Bogging?
#31
I forgot to mention, I havent done the timing on my car.
Would this cause it? It drove fine before without the timing being done, but then again it idled at 2k. I dont know if that made a difference.
#33
Im from Cali, So it would be US.. I swapped in one of those imports with 40k.
#35
It is same type of motor tho. f23a1
#36
I just came home from a 20 minute test drive after I :
Removed throttle body to
>Take off TPS and put it back on since I did mess with throttle stop screw.
and
>Rewired the plug wires to the distributor.
Usually it would start bogging within 5 minutes but it didnt bog at all right now after I did those 2 things. Maybe it will start again later? Hopefully not.
But Im guessing I may have had the wires wrong because they look plugged in different than how I had them when it would bog.
and
#38
This was fixed by replacing the throttle body, I had replaced the TPS throttle position sensor with a BLOX one from ebay, cost me about $20. It went bad after 3 months so I had to get a whole throttle body with an oem TPS. This fixed the bogging issue. It WAS NOT the fuel filter.
Melissa Kaye White
08-24-2013 05:28 PM
byrothapyro
10-05-2010 04:58 PM
