Accord EX Master Window Switch in LX..Will it work?
Hi All,
Has anyone swapped an Accord EX Master Window Switch into LX model?
The connectors on both switches look the same....would be nice to have auto close om passenger side as well.
If it works, I understand there some programming involved as well...
dinky
dinky
The driver's switch may work properly for the auto up/down feature. The issue is that the driver's door switch also communicates in the network through the MICU, so it may not communicate.
The passenger door auto up/down feature may not be easy to do, because the driver's door switch may communicate through the network to do that feature.
If you can find one for cheap at a junkyard it is still worth a shot to try. Let us know what you find.
