Accord Hybrid Batteries
Old 05-20-2013 | 05:04 PM
jpulone's Avatar
Default Accord Hybrid Batteries
Will my car still run with dead hybrid batteries?
What is the going price to replace hybrid batteries?
Old 05-20-2013 | 08:54 PM
Yes.
About $1,500 to $2,000.
The battery to start the engine is ~ $75
Old 05-23-2013 | 11:58 AM
jpulone's Avatar
Poorman, are you in the car business or do you have personal experience with the Accord hybrid. The car is over 90,000 miles and have heard the resale of hybrid goes down considerable because of the cost of batteries, however 1500 to 2000 dollars is not that much for such a great car that should last at least 200,000 miles.
Thanks for any info.
Old 05-24-2013 | 06:24 PM
No personal experience with the hybrid....just reading.
Cars, well +27 years in the automotive industry.
Personally, I'd just drive and worry about the battery for the elect motor if and when it comes about.
Old 05-25-2013 | 01:23 PM
jpulone's Avatar
With dead hybrid batteries, will the engine stop feature no longer work and since I believe with the engine off and you release the brake the electric motor starts the engine again, not the starter motor. So what would happen with engine off feature?
Old 05-25-2013 | 02:56 PM
Pure theory......if the system detects the battery for the electric motor is dead then a fault will be set and a default will be used by the PCM and basically revert the car to a "normal gas engine".
Old 05-27-2013 | 01:44 PM
jpulone's Avatar
Default Trans Fluid change Accord V6 Hybrid
Have 90,000 miles in west coast driving and thought about changing fluid. The book talks about changing the transmission and transfer fluid. What is the transfer fluid and is it all part of the transmission fluid or a separate and is drained at a different location, etc.?
Thanks for any help.
Old 05-28-2013 | 08:06 PM
In the owners manual it should list the how to check/change the "transfer" fluid. If you don't have the owners manual, you can go to Honda's web site and enter your car info and a few other things and then download a pdf version of the owners manual.
Bogus Exception
10-30-2013 12:35 AM
elposton
12-07-2011 12:43 AM
R_ACE1
06-12-2009 01:15 AM
botang47
01-22-2009 09:22 PM
benjiaccord
01-11-2008 02:17 AM
