Accord pulls strongly to the left
Old 11-13-2006 | 05:07 PM
Road Head
Default Accord pulls strongly to the left
Wifey's car (2002 Accord) steered fine when we got it. A couple months ago she got her tires rotated and shortly after it started pulling to the left pretty badly. We took it Saturday to get aligned, and it still pulls to the left, not as severely, but bad enough. I got a lifetime alignment, but really just want to be able to fix it myself if possible. Do I have any options, or should we take it back and get them to check it again? Thanks
Old 11-13-2006 | 06:00 PM
sir_nasty's Avatar
Default RE: Accord pulls strongly to the left
in the DIY section there is a post on how to check/align your vehicle so you can see if it's right yourself.... sounds like it's still out of alignment
Old 11-22-2006 | 03:46 AM
pacifica_kid
it mit be that the tire is a directional. it only go's one way my honda had that problem took to tire shop turned it around and no problems....
Old 11-22-2006 | 08:57 PM
lightshow's Avatar
tire might be separating. if you get them balanced they will be able to tell
Old 11-22-2006 | 09:18 PM
YeuEmMaiMai's Avatar
uneven tire wear will cause alligment problems even when the car is perfectly alligned. check your tires for uneven wear........
Old 11-23-2006 | 03:00 AM
Chiovnidca's Avatar
Try crossing the front tires. Does that change the pull?
bensminger2003
03-11-2012 02:22 PM
accordfan
06-13-2011 11:35 PM
doitmyself
12-21-2010 11:01 AM
pattatat
12-17-2010 08:32 PM
nedpoins
01-06-2006 08:13 PM
