Accord starting hard then check engine light
Old 06-28-2005 | 02:24 AM
Bhersh
Default Accord starting hard then check engine light
I have a 93 Accord SE (Automatic trans)
Okay so about four times now....always first thing in the morning after several hours of sitting time I hop in the Hizzle and its turns over way longer than it should. Maybe a solid three seconds worth. Its not turning over hard though, and it really seems like its a fuel issue. Ive run Lucas fuel treatment through it with every oil change, and within the past three months gave her a tune up (cap, plugs, wires, rotor). After turnng over the three seconds it fires up just like usuall, but the the check engine light stays on. So I let it idle a little and let the oil move around a little. I shut it down and it fires right back up normally!!!! And the light stays off....... Fuel Pump maybe? Any input would be awesome, thanks.
~Bhersh
ericnear
02-21-2013 05:16 PM
landlover
04-15-2012 07:50 AM
SolEX01
08-10-2010 05:04 PM
martymoatw/40'rope
07-30-2009 09:45 PM
bigjayzizzle
08-27-2007 07:49 PM
Quick Reply: Accord starting hard then check engine light
