adjusting air mix cable/blender door
Here are is the vent temperature, low psi, and high psi assuming it is 95 degrees outside with 80% humidity at 1500 rpm. This is from eyeballing that chart:
Vent 70 degrees.
Low 52 psi
High 380
Assuming it is 95 with 30 % humidity:
Temp at vent 57
Low 40 psi
High 300 psi
Vent 70 degrees.
Low 52 psi
High 380
Temp at vent 57
Low 40 psi
High 300 psi
Okay so those pressure readings should be read at 1500rpm and not idl?e
That is from the 94 shop manual that you can download from the online manuals link in the General DIY thread. It says to run the test at 1500 rpm for ten minutes, then take the reading. Take a look at the instructions on how to test.
