Adjusting headlights
Welcome!
The "new member" area is mostly for welcome & introductions, so I'm moving this over to General Tech where more people are likely to see it & help.
Do the adjuster screws not do anything? Or don't move far enough? Are they too high or too low or what?
Yea I messed with the adjuster screws and I got the driver side headlight where it's supposed to be..but now the passenger side is where I'm strugglin..I messed with adjuster screw and cant seem to bring it down do I need to remove the bumper or sumthin?
You should not have to move the bumper. The driver and passenger side are Mirror images.
If the inner screw adjusts the height on the driver side, then the inner screw on the passenger side adjusts the height too.
There are 2 adjustment screws on each headlight.
Are you sure you're turning them in the right direction ( clockwise or counter-clockwise)?
There is a limit. maybe the threads are stripped?
carid
04-07-2015 08:45 AM
Lemonhead228
03-29-2014 07:16 PM
