Air conditioner not blowing cold air
Old 08-07-2007 | 05:50 PM
electromagician
Default RE: Air conditioner not blowing cold air
Hey Mbo, I've had a similar problem with my 97 2.2 EX.
I've replaced both fans, the radiator and I've used a wal-mart special to check the r134 level, and its fine, at least on that side. If it's not hot outside, all is well, but if it's hot I can only get cold air if I am moving. ONce I pull into a drive-through I have about 2 minutes and then all I get is the warm air as if the compressor was not on at all.
What do I look for next? thanks in advance.
Old 09-14-2012 | 09:02 AM
smokeydutch's Avatar
Default No a/c!
i have a 95 honda accord and i just recently recharged my freon and vaccumed and all that good stuff. air blows but not ice cold. put direct power from battery to compressor and it kicked right on and started working. whats my problem here? is it my a/c and heater switch or some cables or something? any help would be greatly appreciated. cant live in the south with no a/c lol
Old 09-14-2012 | 07:52 PM
A bit confused, not hard to do to me.
Does the ac come on when you press the switch, or do you have to "hot wire" the compressor to make it run.
When the ac is running, what are the high and low side pressures?
Do you know if BOTH fans on the rad come on when the car is running - again not sure if the ac works by "just the button".
Next, be sure the heater control valve is closing off - broken ****, cable adjustment, ect......
Old 12-15-2017 | 07:35 PM
rbolognesi's Avatar
Yes, it is an ON/OFF button, so when I press it the fan turns on. It should be another combo of buttons to push that activate the self diagnostic test.
ShetHonda
07-05-2012 11:22 PM
BHoward711
04-12-2010 08:57 PM
brystalhardy
10-15-2009 12:30 AM
jbraly
09-01-2009 01:26 PM
jeremiah6120
04-16-2006 03:32 AM
Quick Reply: Air conditioner not blowing cold air
